tornbjerg Posted December 7, 2009 Share Posted December 7, 2009 (edited) I have created a nurbs surface via a loft and I am trying to use this surface to edit a solid addition. I basically want to carve away the solid to the surface leaving a block with the surface geometry - this would be done on a CNC mill. Thanks in advance for any thoughts. Edited December 8, 2009 by Tech Link to comment
Pat Stanford Posted December 8, 2009 Share Posted December 8, 2009 Section Solids is the command you are looking for. But it did not work with the two objects in your demo file. Perhaps if you used the loft instead of converting it to a solid you would get better results. Link to comment
