Jonathan Pickup
Dealing with DXF/DWG
Short Sharp Training (monthly)
This month the short sharp training will be looking at Best Practice for Importing and Exporting DXG/DWG files. There are times where you can't avoid working with consultants and other CAD users that do not use Vectorworks. In these cases, you need to share information with DXF/DWG. What is the best practice to make it run smoothly?
If you have ever had trouble importing DXF/DWG files, if you have had trouble scaling, or if you are scared of working with DXF or DWG files, this session is for you.
For more information, visit this web site:
http://www.archoncad.co.nz/usergroup/join_int.php
Vectorworkout
Get ready for a better, faster way of learning some areas of Vectorworks. If you don't like reading much, then Vector-workout is for you. If just want to get straight into the movies, with out all the words, then Vector-workout is for you. If you are looking for a training resource that makes it easy to dip into, then Vector-workout is for you.
The movies are stored in a PDF, which make the movies searchable. Now you can look for the movie you want.
Check out this site:
http://www.archoncad.co.nz/training/vector-workout.php
