J Lucas Posted December 4, 2009 Share Posted December 4, 2009 (edited) If I have multiple files open I cannot switch between them by choosing them in the Window drop down menu. Is anyone else having this problem? Edited December 4, 2009 by J Lucas Quote Link to comment
Jaime Posted December 4, 2009 Share Posted December 4, 2009 Yes, I am having the same problem. I keep having to "Open latest drawing". The good thing is that the drawings are staying open in the Resources palette, so I can copy symbols and textures. Quote Link to comment
J Lucas Posted December 4, 2009 Author Share Posted December 4, 2009 Vectorworks tech guys: any suggestions? Is this a known bug? Quote Link to comment
Ray Libby Posted December 4, 2009 Share Posted December 4, 2009 I've seen this pop up a couple of times since version 12 and haven't seen a resolution. -Did you recently install any new software or change anything else on your computer? -If you would post your computer specs including memory and graphics card and version it may help to troubleshoot. -You may want to call tech support. -If you do find a resolution please post it here. Quote Link to comment
KevinSmith Posted December 8, 2009 Share Posted December 8, 2009 This same thing literally just started happening to me. Haven't loaded anything new or recent in a while, but also haven't used Vectorworks heavily in the last few months. Could this be another of those Quicktime related bugs? Running Vectorworks 2009 on: Windows Vista 64 bit ASUS P5Q Pro P45 Mobo Intel Core 2 Duo E8400 3.0 Ghz Asus Radeon HD 4850 512MB Corsair Dominator 4GB RAM Corsair 650TX PSU Thanks for any help Quote Link to comment
WhoCanDo Posted December 9, 2009 Share Posted December 9, 2009 Do the quick keys ctrl-F6 or ctrl-Tab work? Quote Link to comment
C. Andrew Dunning Posted December 9, 2009 Share Posted December 9, 2009 I see this issue quite a bit. I've concluded that (at least @ my end) the problem is linked to the quantity of menu items in a given Workspace. I reach a point at which switching between drawings no longer works; I delete a few items from the menus; all is good again. FWIW, my "every-day" Workspace is from-scratch custom and includes items from the different Designer modules; commands from several 3rd-party packages, one of which adds 50 or 60 commands; and several items of my own. If you've recently modified your Workspace, you might consider doing a little pruning. Quote Link to comment
J Lucas Posted December 9, 2009 Author Share Posted December 9, 2009 Thanks everyone for your replies. The quick keys work fine. Changing to a simpler workspace did not make a difference. Quick keys it is. Quote Link to comment
rdc Posted December 14, 2011 Share Posted December 14, 2011 I submitted a bug report with the same issue. Here's the response I got: try reducing the number of fonts you have installed below 300 to see if it helps? This is a known issue and in most cases reducing the number of fonts installed helps. This fixed the problem. Quote Link to comment
