Script to randomise Z-height within a certain amount
HP Sauce
How would one go about scripting such a thing?
Usage in example:
Ten image prop symbols of a bush are placed at Z0. The user selects the symbols, executes the script, and is asked for a minimum and maximum Z height along with a direction constraint (lower only for example). The script then randomly moves the symbols up or down on the Z plane.
Use Move3DObj(0, 0, dZ); to move an individual object.
To generate a random value between to numbers, use the following function:
function RandVal(LL, UL :Real) :Real;
{ Generate a random value in the range LL -> UL inclusive. }
Begin
UL := UL - LL;
RandVal := Random * UL + LL;
End;		{ RandVal }
By sending the appropriate limits to the RandVal function you can control whether your objects move up or down.
Raymond
Usage in example:
Shouldn't the symbols be Sent to Surface? In the absence of a DTM? Ah-ha! Lower only?
Whatever. I must investigate this in relation to my Forest Simulator.
Forest Simulator... Gold! That looks like a great tool.
Sent to Surface? No sir, this was purely for artsy renderings wherein a row of duplicated bush symbols are not all exactly the same height, producing a much more natural look.
Thanks for the code snippet and direction MullinRJ.
Yes, a great idea, which I may incorporate into my tool, although the main workflow is that after the forest has been created, trees & shrubs are sent to surface. (I use it to create random tree covers as backdrops.)
