wavlas Posted November 30, 2009 Share Posted November 30, 2009 Is there a way (preference) for the object info box to show actual dimensions (x&y) for a rotated rectangle instead of the original with the angle indicated. It seems you must make the rectangle a polygon for this to work. When quickly doing schematics, we use rectangles a lot then duplicating & rotating & reproportioning, etc. Polygons are not as quick. Quote Link to comment
Guest Frank Brault Posted November 30, 2009 Share Posted November 30, 2009 First instituted in Vectorworks 2008, the rectangle tool creates a rectangle that stays a rectangle even after it is rotated. hth, Quote Link to comment
WhoCanDo Posted December 1, 2009 Share Posted December 1, 2009 I'm like you so check out the bottom post of the following link: http://techboard.nemetschek.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=131057&Searchpage=1&Main=26988&Words=WhoCanDo&Search=true#Post131057 I created this as a tool and it works well. Quote Link to comment
