Subtraction Solids.
Assembly
currently I am trying to use the subtractsolid tool to subtract one PIO from another PIO.
I have a simple PIO Extrude:
PROCEDURE SetObjectParameter;
Begin;
SetRField(HObject,ObjectName,'FrameWidth',Num2Str(1,FrameWidth));
SetRField(HObject,ObjectName,'FrameDepth',Num2Str(1,FrameDepth));
SetRField(HObject,ObjectName,'ExtrudeStart',Num2Str(1,ExtrudeStart));
SetRField(HObject,ObjectName,'ExtrudeFinish',Num2Str(1,ExtrudeFinish));
ObjectName:='0 ASHFRAMEPIO';
HObject:= CreateCustomObjectN(ObjectName,0,0,0,False);
SetObjectParameter;
Then within Vectorworks I have created a solid box extrusion that intersects the PIO.
By using the Subtract Solids function within vectorworks, I am able to subtract the box from the PIO.
---converting the result to a symbol and exporting as vectorscript allows me to see what process vectorworks uses to carry out this procedure.
tempHandle2 := CreateCustomObject('0 ASHFRAMEPIO',0,0,#0.0000000000000d);
ResetOrientation3D;
Rotate3D(#0.0000000000000d,#-0.0000000000000d,#0.0000000000000d);
Move3D(-5020.000000000000909,300.000000000000057,0);
Record(LNewObj,'0 ASHFRAMEPIO');
Field(LNewObj,'0 ASHFRAMEPIO','LineLength','1320.000000000000227');
Field(LNewObj,'0 ASHFRAMEPIO','FrameWidth','45');
Field(LNewObj,'0 ASHFRAMEPIO','FrameDepth','90');
Field(LNewObj,'0 ASHFRAMEPIO','WallH','2400');
Field(LNewObj,'0 ASHFRAMEPIO','Spacing','450');
Field(LNewObj,'0 ASHFRAMEPIO','TopPlateFalls','0');
Field(LNewObj,'0 ASHFRAMEPIO','DwangSpacing','800');
BeginXtrd(0,1560.000000000000455);
Rect(-4280.000000000000909,900.000000000000227,-3120.000000000000909,-440.000000000000114);
EndXtrd;
ResetOrientation3D;
Rotate3D(#-0.0000000000000d,#0.0000000000000d,#-0.0000000000000d);
Move3D(0,0,240.000000000000057);
tempHandle1 := LObject;
tempHandle := PrevObj(tempHandle1);
result := SubtractSolid(tempHandle, tempHandle1, tempHandle2);
ResetOrientation3D;
Move3D(4360.000000000000909,-345.000000000000057,-1155.000000000000227);
My problem is, by simply copying this code to a new vectorscript, the result from the subtraction process returns -20- (meaning a bad input).
---Is there a way through script, to subtractsolid from PIO's? I would like to end up subtracting one PIO from another PIO.
