Assembly Posted November 24, 2009 Share Posted November 24, 2009 (edited) Trying to script view ports. I have managed to create a view port and turn on the current active layer with this snip: ShowLayer:=0; hLayerCurrent:=ActLayer; hLayer:=CreateLayer(LayerNameString,2); hVP:=CreateVP(hLayer); result:=SetVPLayerVisibility(hVP,hLayerCurrent, ShowLayer); How do I cycle the full list of layers to turn on? How do I cycle the full list of classes to turn on?. Edited November 24, 2009 by Assembly Quote Link to comment
Pat Stanford Posted November 24, 2009 Share Posted November 24, 2009 Sort the Function Reference by Class. The Layers section gives you all the information on layer. FLayer will give you a handle to the first layer. Document List Handling section gives you NextLayer and PrevLayer Classes gives you ClassNum that returns the total number of classes in the file. ClassList(X) will give you the name of the class that is number X in the drawing. You will need to create a loop for Layers and another for Classes and manually go through and get all the names you need. Quote Link to comment
BillW Posted January 14, 2010 Share Posted January 14, 2010 I just had a dig around some ancient code which may be useful I used two procedures for manipulating VP classes and layers with a range of options including wildcarding names. Restricted to maximum 200 classes and 200 layers. procedure example; {By Bill Wood 2010} Const {Viewport layer and class visibility} kVISIBLE = 0; kINVISIBLE = 1; kGREYED = 2; {Viewport Class/Layer build} kNOCHECK = 1; kINCLUSION = 2; kEXCLUSION = 3; {Layer names} kGRIDLYR = 'Grid layer'; kSHEDLYR = 'Build layer'; Var vpH : HANDLE; classnames,layernames : array[1..200] of STRING; classcnt : INTEGER; procedure setvpclassvis(vportH : HANDLE; classnames : array[1..200] of STRING; classcnt,genmethod,visibility : INTEGER; forceothersalternate : BOOLEAN); Label 100,150; Var i,j,altvisible : INTEGER; classfnd,btest : BOOLEAN; classtest : array[1..200] of BOOLEAN; classstr : array[1..200] of STRING; starpos : INTEGER; begin case visibility of kINVISIBLE: altvisible := kVISIBLE; kVISIBLE: altvisible := kINVISIBLE; end; case genmethod of kNOCHECK: begin for i := 1 to classcnt do btest := setvpclassvisibility(vportH,classnames,visibility); end; kINCLUSION: begin for i := 1 to classcnt do begin starpos := pos('*',classnames); classtest := (starpos <> 0); if classtest then begin if (starpos = 1) then classstr := copy(classnames,2,len(classnames)-1) else classstr := copy(classnames,1,starpos-1); end else classstr := classnames; end; for i := 1 to classnum do begin classfnd := FALSE; for j := 1 to classcnt do begin if classtest[j] then classfnd := (pos(classstr[j],classlist(i)) <> 0) else classfnd := (classstr[j] = classlist(i)); if classfnd then goto 100; end; 100: if classfnd then btest := setvpclassvisibility(vportH,classlist(i),visibility) else if forceothersalternate then btest := setvpclassvisibility(vportH,classlist(i),altvisible); end; end; kEXCLUSION: begin for i := 1 to classcnt do begin starpos := pos('*',classnames); classtest := (starpos <> 0); if classtest then begin if (starpos = 1) then classstr := copy(classnames,2,len(classnames)-1) else classstr := copy(classnames,1,starpos-1); end else classstr := classnames; end; for i := 1 to classnum do begin classfnd := FALSE; for j := 1 to classcnt do begin if classtest[j] then classfnd := (pos(classstr[j],classlist(i)) <> 0) else classfnd := (classstr[j] = classlist(i)); if classfnd then goto 150; end; 150: if classfnd then btest := setvpclassvisibility(vportH,classlist(i),visibility) else if forceothersalternate then btest := setvpclassvisibility(vportH,classlist(i),altvisible); end; end; end; end; {setvpclassvis} procedure setvplayervis(vportH : HANDLE; layernames : array[1..200] of STRING; lyrcnt,genmethod ,visibility : INTEGER; forceothersalternate : BOOLEAN); Label 100,150; Var i,j,altvisible : INTEGER; layerfnd,btest : BOOLEAN; lyrH : HANDLE; lyrname : STRING; begin case visibility of kINVISIBLE: altvisible := kVISIBLE; kVISIBLE: altvisible := kINVISIBLE; end; case genmethod of kNOCHECK: begin for i := 1 to lyrcnt do btest := setvplayervisibility(vportH,getlayerbyname(layernames),visibility); end; kINCLUSION: begin lyrH := flayer; while (lyrH <> NIL) do begin layerfnd := FALSE; lyrname := getlname(lyrH); for j := 1 to lyrcnt do begin if (layernames[j] = lyrname) then begin layerfnd := TRUE; goto 100; end; end; 100: if layerfnd then btest := setvplayervisibility(vportH,lyrH,visibility) else if forceothersalternate then btest := setvplayervisibility(vportH,lyrH,altvisible); lyrH := nextlayer(lyrH); end; end; kEXCLUSION: begin lyrH := flayer; while (lyrH <> NIL) do begin layerfnd := FALSE; lyrname := getlname(lyrH); for j := 1 to lyrcnt do begin if NOT (layernames = lyrname) then begin layerfnd := TRUE; goto 150; end; end; 150: if layerfnd then btest := setvplayervisibility(vportH,lyrH,visibility) else if forceothersalternate then btest := setvplayervisibility(vportH,lyrH,altvisible); lyrH := nextlayer(lyrH); end; end; end; end; {setvplayervis} begin {create viewport first} layernames[1] := kGRIDLYR; layernames[2] := kSHEDLYR; setvplayervis(vpH,layernames,2,kNOCHECK,kVISIBLE,FALSE); classnames[1] := 'Concrete-Panel*'; classnames[2] := 'Cladding*'; classnames[3] := 'Flashing*'; setvpclassvis(vpH,classnames,3,kEXCLUSION,kINVISIBLE,TRUE); {Alternatively} classcnt := 1; classnames[classcnt] := 'Colour*'; classcnt := classcnt + 1; classnames[classcnt] := 'Purlin Bay-Wall-A1:A*'; setvpclassvis(vpH,classnames,classcnt,kINCLUSION,kVISIBLE,FALSE); end; run(example); Quote Link to comment
brudgers Posted January 15, 2010 Share Posted January 15, 2010 Just a thought, but it might be easier to modify the built in standard view tools if you have Architect. Quote Link to comment
