Turning on Classes in ViewPort Script.
Assembly
Trying to script view ports.
I have managed to create a view port and turn on the current active layer with this snip:
ShowLayer:=0;
hLayerCurrent:=ActLayer;
hLayer:=CreateLayer(LayerNameString,2);
hVP:=CreateVP(hLayer);
result:=SetVPLayerVisibility(hVP,hLayerCurrent, ShowLayer);
How do I cycle the full list of layers to turn on?
How do I cycle the full list of classes to turn on?.
Edited by Assembly
Sort the Function Reference by Class.
The Layers section gives you all the information on layer. FLayer will give you a handle to the first layer.
Document List Handling section gives you NextLayer and PrevLayer
Classes gives you ClassNum that returns the total number of classes in the file. ClassList(X) will give you the name of the class that is number X in the drawing.
You will need to create a loop for Layers and another for Classes and manually go through and get all the names you need.
  • 1 month later...
I just had a dig around some ancient code which may be useful
I used two procedures for manipulating VP classes and layers with a range of options including wildcarding names.
Restricted to maximum 200 classes and 200 layers.
procedure example;
{By Bill Wood 2010}
Const
{Viewport layer and class visibility}
kVISIBLE = 0;
kINVISIBLE = 1;
kGREYED = 2;
{Viewport Class/Layer build}
kNOCHECK = 1;
kINCLUSION = 2;
kEXCLUSION = 3;
{Layer names}
kGRIDLYR = 'Grid layer';
kSHEDLYR = 'Build layer';
Var
vpH : HANDLE;
classnames,layernames : array[1..200] of STRING;
classcnt : INTEGER;
procedure setvpclassvis(vportH : HANDLE; classnames : array[1..200] of STRING; classcnt,genmethod,visibility : INTEGER; forceothersalternate : BOOLEAN);
Label 100,150;
Var
i,j,altvisible : INTEGER;
classfnd,btest : BOOLEAN;
classtest : array[1..200] of BOOLEAN;
classstr : array[1..200] of STRING;
starpos : INTEGER;
begin
case visibility of
kINVISIBLE: altvisible := kVISIBLE;
kVISIBLE: altvisible := kINVISIBLE;
end;
case genmethod of
kNOCHECK: begin
for i := 1 to classcnt do btest := setvpclassvisibility(vportH,classnames,visibility);
end;
kINCLUSION: begin
for i := 1 to classcnt do begin
starpos := pos('*',classnames);
classtest := (starpos <> 0);
if classtest then begin
if (starpos = 1) then classstr := copy(classnames,2,len(classnames)-1)
else classstr := copy(classnames,1,starpos-1);
end
else classstr := classnames;
end;
for i := 1 to classnum do begin
classfnd := FALSE;
for j := 1 to classcnt do begin
if classtest[j] then classfnd := (pos(classstr[j],classlist(i)) <> 0)
else classfnd := (classstr[j] = classlist(i));
if classfnd then goto 100;
end;
100: if classfnd then btest := setvpclassvisibility(vportH,classlist(i),visibility)
else if forceothersalternate then btest := setvpclassvisibility(vportH,classlist(i),altvisible);
end;
end;
kEXCLUSION: begin
end
end;
classfnd := FALSE;
if classfnd then goto 150;
end;
150: if classfnd then btest := setvpclassvisibility(vportH,classlist(i),visibility)
end;
end;
end;
end; {setvpclassvis}
procedure setvplayervis(vportH : HANDLE; layernames : array[1..200] of STRING; lyrcnt,genmethod ,visibility : INTEGER; forceothersalternate : BOOLEAN);
Label 100,150;
Var
layerfnd,btest : BOOLEAN;
lyrH : HANDLE;
lyrname : STRING;
begin
case visibility of
end;
case genmethod of
kNOCHECK: begin
for i := 1 to lyrcnt do btest := setvplayervisibility(vportH,getlayerbyname(layernames),visibility);
end;
kINCLUSION: begin
lyrH := flayer;
while (lyrH <> NIL) do begin
layerfnd := FALSE;
lyrname := getlname(lyrH);
for j := 1 to lyrcnt do begin
if (layernames[j] = lyrname) then begin
layerfnd := TRUE;
goto 100;
end;
end;
100: if layerfnd then btest := setvplayervisibility(vportH,lyrH,visibility)
else if forceothersalternate then btest := setvplayervisibility(vportH,lyrH,altvisible);
lyrH := nextlayer(lyrH);
end;
end;
kEXCLUSION: begin
lyrH := flayer;
layerfnd := FALSE;
if NOT (layernames = lyrname) then begin
layerfnd := TRUE;
goto 150;
end;
end;
150: if layerfnd then btest := setvplayervisibility(vportH,lyrH,visibility)
end;
end;
end;
end; {setvplayervis}
begin
{create viewport first}
layernames[1] := kGRIDLYR;
layernames[2] := kSHEDLYR;
setvplayervis(vpH,layernames,2,kNOCHECK,kVISIBLE,FALSE);
classnames[1] := 'Concrete-Panel*';
classnames[2] := 'Cladding*';
classnames[3] := 'Flashing*';
setvpclassvis(vpH,classnames,3,kEXCLUSION,kINVISIBLE,TRUE);
{Alternatively}
classcnt := 1;
classnames[classcnt] := 'Colour*';
classcnt := classcnt + 1;
classnames[classcnt] := 'Purlin Bay-Wall-A1:A*';
setvpclassvis(vpH,classnames,classcnt,kINCLUSION,kVISIBLE,FALSE);
end;
run(example);
