D Wood Posted November 21, 2009 Share Posted November 21, 2009 (edited) I am trying to show a perspective view of my house model on the site model. I'm still on VW12.5, so I have made one viewport with Final Quality rendering at the back, and one in Hidden Line in front. I want to soften the impact of the Hidden Line render, so I have changed the line colours in all the Viewport classes to a dark grey. However some lines, particularly around windows, still show up as black. Is the colour of these lines determined by something other than class? Edited November 21, 2009 by D Wood Quote Link to comment
gScott Posted November 21, 2009 Share Posted November 21, 2009 if the viewport class over-ride grey colours are not working it is most likely that those objects are not drawn using the class style for pen colour. alternatively if you are using the windoor tool for your doors + windows check that the default class settings for the windoor classes are set to "use at creation" for the graphic attributes. i tried a render like yours + found that my default windoor classes weren't set to "use at creation" + it rendered the same as yours. on re-setting the classes you also have to regenerate each windoor element to get the new settings to take. e.g. click on each windoor element + toggle, say, "opaque glass" on + off . smarter people than me will have a better way to do this, but it works for me, and your model doesn't look too big... this may also apply to the VW window tool, but it rendered fine in my test so i am guessing it's "windoor" hth Quote Link to comment
D Wood Posted November 21, 2009 Author Share Posted November 21, 2009 Gideon Thank you for your response - indeed, as you suspected some of the WinDoor classes were N for Use at Creation (I must say, I've never understood what this option was for, when you should choose No and when Yes). Anyway, just changing them all to Y did not make a difference in itself, but clicking on each door, window and symbol in turn, then Class Settings, then threatening to Reset (click Reset, then No) did work - all the Hidden Line Renders now draw with dark grey lines. Thanks for your help! Quote Link to comment
gScott Posted November 21, 2009 Share Posted November 21, 2009 david it generally makes sense for the "use at creation" setting to be ON so that viewports can be altered as above, and for greater speed of drawing if you are rigorous in your use of classes. e.g. in my case: structure-existing = thick black pen + grey hatch structure-brick = thick black pen + red hatch structure-conc = thick black pen + green hatch structure-demolished = medium dashed red pen + no fill etc etc the weirdness here is that windoor has graphic styles of its own that can get confused with the normal class styles. the only class that i set OFF for "use at creation" is windoor's 2D objects/swing class so that windoor can set the swing to be different to the door + jambs Quote Link to comment
