D Wood Posted November 21, 2009 Share Posted November 21, 2009 I am trying to show a perspective view of my house model on the site model. I'm still on VW12.5, so I have made one viewport with Final Quality rendering at the back, and one in Hidden Line in front. The problem is that the site model in Hidden Line render generates lines between contours (either 3d triangles or grid) when I just want to see smooth ground with contour lines. If I apply a class to the site model and turn it off in Hidden Line, the house model basement shows. Is there any other way to have Hidden Line without the lines on the site model? Quote Link to comment
CipesDesign Posted November 21, 2009 Share Posted November 21, 2009 The only way to do this that I am aware of is to not show the Site Model (either by Layer or by Class) in the HL Rendering VP.... Quote Link to comment
D Wood Posted November 21, 2009 Author Share Posted November 21, 2009 Thank you, Peter, I think you're right. I've turned off the site model class, converted the HL viewport to lines, then edited out everything below ground. This actually gives more control over all the lines, but it means that if the design changes, I have to re-edit the lines. Quote Link to comment
billtheia Posted November 22, 2009 Share Posted November 22, 2009 Could you just render the site model using OpenGL or RW in one VP and the house in another VP using hidden line? Quote Link to comment
CipesDesign Posted November 22, 2009 Share Posted November 22, 2009 That's exactly what he did, but the HL VP has to be on the top, thus all the sub-grade objects would show.... Bummer... But I think how he solved it is workable, except, as he stated, if changes need to be made. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted April 30, 2010 Vectorworks, Inc Employee Share Posted April 30, 2010 Within the hidden line render, you can set a smoothing angle which will help remove some of the lines. Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted April 30, 2010 Vectorworks, Inc Employee Share Posted April 30, 2010 Not sure but have you tried setting the line type for the object to None (rather than solid)? Quote Link to comment
kgroob Posted April 30, 2010 Share Posted April 30, 2010 Also, you could try using the artistic renderworks and set it to "Tapered Lines". Turn the wobble down. Not sure if the extra lines of the model would show up, but it could work. I have used this rendering method before, then brought the final quality & line renderings into photoshop and superimposed them. You can tone down the color in the final quality image with a translucent white mask, then put the black lines on top. It gives a nice effect for a presentation. Quote Link to comment
