da_muel Posted November 19, 2009 Share Posted November 19, 2009 Hi, Im trying to figure out how to view an object while Im moving around it using the flyover tool. In VW 2008 I was able to have the model displayed in hidden line, then I could select the flyover tool, move around the object and everything would display as wire frame so I knew where I was. When I stopped using the flyover tool the scene would re-render in hidden line. Now in VW 2010 if I select hidden line render and then try to use the flyover tool, the model disappears until I stop rotating, then it re-renders in hidden line. Its really hard to orientate myself when I cant see the model, especially when trying to set views for viewports. Does anyone know how I can change this so that the model will display in wireframe when the flyover tool is being used and then re-render in hidden line. Thanks Quote Link to comment
CipesDesign Posted November 19, 2009 Share Posted November 19, 2009 AFAIK, the flyover tool is intended for use in Open GL. Hidden line always has and always will cause re-renders after each change of view... Quote Link to comment
