FRED JOHNSON Posted November 13, 2009 Share Posted November 13, 2009 Is it possible to import a jpeg digital photo of carpet into renderworks and use it as a flooring material in a room rendering. If so, exactly how - new to renderworks. Quote Link to comment
Ray Libby Posted November 13, 2009 Share Posted November 13, 2009 You don't import the image into Vectorworks, you create a texture using the image. In the resource browser you will see two small triangles on the upper right, click on the bottom one. Choose New Resource in (file name)>Renderworks Texture... This will bring up the Edit Texture dialog box. Name your texture then in the Color: pull down menu choose Image Color* and you will get a dialog box to choose the image. Quote Link to comment
FRED JOHNSON Posted November 13, 2009 Author Share Posted November 13, 2009 Thanks Ray, I'll give it a try, sort of a one time thing. Quote Link to comment
bcd Posted November 14, 2009 Share Posted November 14, 2009 ... then when you have your texture you will need an object (floor) to apply it to. You can create a polygon & extrude it a little then from the Resource Browser drag and drop the texture onto it. Be sure your polygon has a fill otherwise the texture won't be visible when you render the model. Quote Link to comment
