eas 0 Posted November 12, 2009 Is there any way to turn off the borders/lines in a worksheet? I would like to use a worksheet to print a drawing list but don't want lines between the items. Tried changing the line weight to 0 but it doesn't stick. Quote Share this post Link to post
Jeffrey W Ouellette 3 Posted November 12, 2009 Select the worksheet, then go to your Attributes Palette and select "None" for the Pen settings. Quote Share this post Link to post
michaelk 466 Posted November 12, 2009 Once the worksheet is placed in the drawing, select the worksheet, and in the attributes palette change the line attribute from solid to none. hth michaelk Quote Share this post Link to post
Jonathan Pickup 273 Posted November 13, 2009 there is a better way to do this, open the worksheet. go to the worksheet menu, the downturned arrow choose Preferences... turn off the Show grid option. Now you can go back to format cells to add a border to the cells you want, or have a line around the outside of the worksheet. I've written a couple of short sharp manuals on worksheets. Quote Share this post Link to post
