sancho1981 Posted November 12, 2009 Share Posted November 12, 2009 Hey, I have VW2009. Is there a way to change/eliminate the containers around focus points? Also, is there a way to change the look of the Lighting Position inventory? Thanks in advance! Shawn Quote Link to comment
GMont Posted November 12, 2009 Share Posted November 12, 2009 In 2008 you selected the focus point and then go to where you change the line weight. Turn the line off there and that should make the container invisible. Quote Link to comment
sancho1981 Posted November 12, 2009 Author Share Posted November 12, 2009 That worked. Many thanks!!! Shawn Quote Link to comment
GMont Posted November 12, 2009 Share Posted November 12, 2009 Glad to here it. For your other question once you put the symbol in your file you edit it like you would any other symbol. Right click on it and select edit. After that it will ask you 2d, 3d and a couple of other things. Select which you want to change and then it will take you to that component of the symbol and you can make what ever changes you want. If you are wanting to change the library itself I recommend finding the file and coping it under a new name. Then open the copy and edit it the same way. From what I can tell the Library file are just VW files with nothing in them but symbols. Hope this is helpful. Quote Link to comment
LightGuy145 Posted November 13, 2009 Share Posted November 13, 2009 What do you mean by lighting position inventory? Do you mean the position summary for the lighting position, where you can sum insts, sum colors, sum circuits...? Do you know how to change the formatting of the position summary? (Font style and size, text positioning, etc). I am having a problem where the "Num Required Circuits:" is too big to fit in its container. The titles like "Instrument Summary" and "Color Summary" are shifted down slightly and also do not fit in their containers. I am using VectorWorks 2009. Quote Link to comment
sancho1981 Posted November 14, 2009 Author Share Posted November 14, 2009 Thanks Gregory! I will give it a shot tonight. Smatticus, yes that is what I mean; the position summary. I will play with it and post what I find. Shawn Quote Link to comment
