$INCLUDE files on network.
Assembly
Nope.
In OSX (at least recent versions), all disks (other than the startup disk) are listed as being in a "virtual" folder called Volumes.
So if I have a folder named Files_to_swap that is sitting on a disk on a different computer on the network that is mounted as SharedFiles, the actual path to the folder is:
/Volumes/SharedFiles/Files_to_swap
The / at the very beginning tells the search to start at the root level of the directory tree.
Note that I used the wrong slashes in my earlier post. The ones in this post are correct.
so:
/Volumes:= the directory where remote disks are mounted on your machine
/That_Mounted_Disk:= the name of the remote disk is mounted as
/This/Folder/Here/VS_Stuff.ps:=The folder path on the remote disk.
