Kellie Posted November 5, 2009 Share Posted November 5, 2009 Is there any way to use the 'Export dwg/dxf' script so that the name of the file it creates is determined by an object named on the page? I need to batch export each sheet in a vectorworks document and the hangup is that the export script brings up a 'save' popup to name the file - which is a problem if you have 50 sheets in the one file that all need to be exported. Would be nice to have that Export Dwg/Dxf script unlocked too to predetermine the settings Quote Link to comment
