BenW Posted October 30, 2009 Share Posted October 30, 2009 In this case, I'm working on a small kitchen. Is there a way to view a wall in an orthographic projection view while there are other walls and or cabinets in the foreground with out seeing the other foreground walls, elements, etc.? I know that I could assign some class and hide the class, but that seems very clunky as what would be hidden in one view would need to be visible in another view. There's got to be an easy way of doing this. Another example of this issue would be to create a camera view that is obstructed by a series of walls, cabinets, etc.? Any advice would be most appreciated. Quote Link to comment
CipesDesign Posted October 30, 2009 Share Posted October 30, 2009 You can use the RW's CAMERA to set a view that is just inside of the (offending) wall. Even so, this is sometimes still too close, so your class idea might work better... Quote Link to comment
Pat Stanford Posted October 30, 2009 Share Posted October 30, 2009 Another possibility is to temporarily make a group of the portion you want to work on and then edit the group. If you have the preferences set to not show other objects while in group you will only see the parts you grouped. Quote Link to comment
