Lenb Posted October 28, 2009 Share Posted October 28, 2009 I'm sorry if this is a simple question but I've tried the Help system and did a search here but couldn't locate my trouble. I have a File containing a 2 story house. I've used the plug-in objects for windows and doors and the settings tab in the OIP. When I go to create a door or window schedule one is created however, I cannot seem to find a way to edit out some of the columns which I don't need. I've previously done this by editing the Door and Window Records however the file only has an "Equipment Record" and a "Plumbing Fixture Record" (which were there by default or brought in with a symbols perhaps and cannot be removed - the option is grayed out) So I'm not clear on where the records are that the Door and Window "VA Create Schedule" command uses. They are not listed in the Resource Browser. Any help would be appreciated. Regards Len Vectorworks 2009 MAC 10.5.8 Quote Link to comment
Pat Stanford Posted October 29, 2009 Share Posted October 29, 2009 The record is part of the door or window Plug-in object, so you can't/don't want to edit it. Once you have the schedule created, just select the columns you don't want, go to the small down facing trigangle over the row headers to get the Worksheet menu, and select Delete Column (or something like that). Once you have the worksheet looking the way you want, save it in a file in: User Folder:Library:Application Support:Vectorworks:2009:Libraries:Defaults:Report~Schedules You can name the file anything you want. This will make your edited scheuld available from the Create Schedule menu item. After you restart VW. Quote Link to comment
Lenb Posted October 29, 2009 Author Share Posted October 29, 2009 Thanks for the response. I have no trouble deleting the columns I don't want and thanks for the tip on saving it for future use. What I'm not able to do is add a column from the PIO thats missing in the default schedule. The "Location" field does not appear on the schedule. Is there anyway to add in the missing info? Quote Link to comment
Pat Stanford Posted October 29, 2009 Share Posted October 29, 2009 Put in a new column and set the formula to ='Door'.'Location' The Door part specifies the name of the record. The Location part is the name of the field in the record. I have a script available in the Vectorscript Sharing forum that will create a worksheet showing all of the available fields of a PIO and even includes a cell with the exact formula you need so you can just copy and paste it into your schedule. http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=108487#Post108487 Quote Link to comment
Lenb Posted October 29, 2009 Author Share Posted October 29, 2009 Thanks very much for the help and pointer to the script. It works just as I needed. Quote Link to comment
shr Posted March 15, 2011 Share Posted March 15, 2011 Hello, found this old post and wish to ask in regards to VW2011 - where is the option to add the formula? I have added a new column, but when I go to the window cell I cannot write any text (greyed out) let alone see anywhere to add a formula. Quote Link to comment
Pat Stanford Posted March 15, 2011 Share Posted March 15, 2011 With the worksheet open for editing, goto the little black disclosure triangle near th top left of the worksheet. Make sure you have a checkmark next to Database Headers. With this selected you should get an integer row for the database (ie 4, not 4.1, 4.2, etc.) In the database header row you should be able to enter the formulas. If your formula is just a reference to a field in a record, you will be able to type into that cell in the database rows (4.1, 4.2, etc.). If the field is anything other than a reference to a record field you will not be able to type into the cell (if your field is something like =area that is a calculated value, you won't be able to change it on the worksheet). If this does not make sense, please write back. Quote Link to comment
carefulsmelly Posted March 15, 2011 Share Posted March 15, 2011 Hi there, Following up this topic - I have a Door Schedule in a worksheet using database information from Vectorworks Doors. This all works fine, except if I carry out any multiple object data changes i.e. change all doors to a 42mm jamb. The change will not show up on the worksheet until I open the settings for each door individually and simply close it again. After this the worksheet will update correctly. Am I missing something or is this a glitch? Quote Link to comment
Farookey Posted March 15, 2011 Share Posted March 15, 2011 Hello, It seems to be working for me.... After making changes... do you recalculate the worksheet? Can you go through exactly what you're doing, so I can better understand your issue? Quote Link to comment
carefulsmelly Posted March 15, 2011 Share Posted March 15, 2011 Hi, I have a worksheet set up with database headers referring to Plugin Doors. Each column head refers to door leaf width, height etc. This all works fine, and if I update a singular door on either the worksheet or the door itself the worksheet updates after I recalculate it. However, if I select say 4no. doors at the same time and change a piece of data - say the jamb width - the changes will not be reflected in the worksheet even after recalculating the worksheet. The only way I have found of getting the changes to be picked up is to open the settings of each door, do nothing, then click ok. Its as if the changes aren't 'registered' by the worksheet unless each and every door that is changed is individually done. Hope this make it a bit clearer - any ideas? Quote Link to comment
Pat Stanford Posted March 15, 2011 Share Posted March 15, 2011 If after changing the multiple doors you go back to the worksheet and click on the small black "Disclosure Triangle" at the top left of the worksheet and choose Recalculate do you get the changes showing? If not there is a problem. If it works, then all is as it should be. Quote Link to comment
carefulsmelly Posted March 16, 2011 Share Posted March 16, 2011 Hi Pat, You hit the nail on the head - the recalculate does not bring in all the changes. I created a brand new file, using only the VW template file and standard doors and the same problem exists - but strangely it only occurs with calculated figures as far as I can see - i.e. Rough Openings (sum of shim gap, door leaf etc). Jamb widths do update after recalculate. Is this a glitch with VW2008? Quote Link to comment
Pat Stanford Posted March 16, 2011 Share Posted March 16, 2011 Sounds like it might be a 2008 problem. That was so long ago that I don't remember. Quote Link to comment
carefulsmelly Posted March 16, 2011 Share Posted March 16, 2011 Pat, Does that mean this issue does not occur in the latest release? Quote Link to comment
Pat Stanford Posted March 16, 2011 Share Posted March 16, 2011 I just tired it in VW2011. New Drawing. Put seven doors in the drawing marked them on schedule. Created Door Schedule (Tools:Reports:VA Create Schedule). Selected three doors and changed the Jamb width from 3/4" to 12". Recalculated worksheet. The jamb widths updated to the correct settings. Quote Link to comment
taliho Posted March 16, 2011 Share Posted March 16, 2011 Once you have the worksheet looking the way you want, save it in a file in: User Folder:Library:Application Support:Vectorworks:2009:Libraries:Defaults:Report~Schedules You can name the file anything you want. This will make your edited scheuld available from the Create Schedule menu item. After you restart VW. Just picked up this thread and exactly what I needed - thanks. Are the steps to save the worksheet as a menu item the same? (substituting 2011, I assume) Tali Quote Link to comment
carefulsmelly Posted March 17, 2011 Share Posted March 17, 2011 Pat, Thanks for trying this out in VW2011, however the jamb width didn't cause problems in VW2008. It seemed to be limited to data that required calculations i.e. rough openings. Quote Link to comment
Farookey Posted March 17, 2011 Share Posted March 17, 2011 I'll have to try it when I get home on 2008... But it seems to be working correctly in 2011 (data requiring calculations). Quote Link to comment
carefulsmelly Posted March 21, 2011 Share Posted March 21, 2011 Anyone have any luck replicating the issue in VW2008? Quote Link to comment
carefulsmelly Posted March 30, 2011 Share Posted March 30, 2011 Anyone have time to look at this on VW2008? Quote Link to comment
Pat Stanford Posted March 30, 2011 Share Posted March 30, 2011 I just tried it in VW2008 and I am seeing what you see. The Rough Opening calcs do not update until you open the settings dialog box. I tried a VectorScript to reset the doors and even that does not seem to make the changes take. I think you are out of luck if you want or need to stay with VW2008. Quote Link to comment
carefulsmelly Posted March 31, 2011 Share Posted March 31, 2011 Thanks for checking this out, much appreciated. Fingers crossed we upgrade soon! Quote Link to comment
