DLVP Glitch? Help!
[The layer "NNA#8#2_Mod-Unit-22-2" in the active document is not from the referenced document "Level 3.vwx". You must rename this layer before a layer with the same name can be referenced.]
I have a building plan containing referenced unit plans.
I then referenced the entire building plan on a new file to create misc sheets. The new file does not contain any other layers except the layer containing the dlvp. And only the unit plan viewport that is named "Mod-Unit-22-2" from the original unit plan can't be brought in.
The problem is solved temporarily if I deleted the dlvp and re-referenced it in, but same thing will happen again when I reopen the file.
Any ideas what's going on here? help.
  • 2 weeks later...
