Daryl Wood Posted October 27, 2009 Share Posted October 27, 2009 I have a large roof face with multiple ridges at different elevations. See attached gif file. One of the ridges thinks it's a square eave. Is there a way to edit this ridge section to return it to a plumb cut, and have the eave remain square? Quote Link to comment
CipesDesign Posted October 27, 2009 Share Posted October 27, 2009 Hi Daryl, try the attachment again.... Quote Link to comment
Daryl Wood Posted October 28, 2009 Author Share Posted October 28, 2009 Hi Peter, Here is the file. Quote Link to comment
CipesDesign Posted October 28, 2009 Share Posted October 28, 2009 Hi Daryl, I tried to recreate a similar roof face in both 2009 and 2010. In both case it worked as expected. I'm curious, when you double click on the roof face, does the underlying polygon have a vertex (or two) left up near where the ridge would be if it was higher?? In this case it might be that VW's is seeing this "ridge" as a part of a "hole" and is drawing the angle based on the "holes" field in the OIP. If so, try deleting the vertex(ices)(or changing the "holes" setting and see what happens. Otherwise I recommend redrawing the shaped in plan view and trying a brand new create roof face command on it. Let me know what you find... Quote Link to comment
