Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Jules2009
How do you change z elevation values on individual 3D objects?
Hi guys
I have had this problem for quite some time where i have had to import a 3d object such as a table, bench, etc from the resource browser but when the object is in there its at an z elevation of zero. I would typically have a few level changes in my designs so some of the objects end up being underground. Then if you try z value in the object info you find that there is no where to do this.
To fix this i have been creating different design layers for each level then changing the z value to desired in the layer in edit design layers.
Is there anyway to change the z value of an individual object if you cant in the object info panel?
Thanks
Probably the easiest and most accurate way is to use Move 3D (By menu command Modify>Move>Move 3D or by keyboard Command+Option+m on a Mac). The dialog will allow you to enter a delta Z distance, either positive or negative.
Alternately you could drag the object while in a front/back/side view.
KM
