vectorscript message using window plugin
Mike,
That message is specific to VectorWorks Architect. Many of the Architect tools and command have the ability to be customized in some way. These customizations correspond to a group of preferences, be it the VectorWorks defaults or any of the custom sets pre made for you.
To choose a set, make sure you are in your Architect workspace, go to the file menu and select Architect Preferences. Then VA Set Project Prefs. Select a set and click the done button.
All of these sets start off identical to the VectorWorks defaults. Alternatively you can also begin your document by using the setup assistant which will set this for you.
Matthew Giampapa
Technical Support
quote:
Originally posted by mike46:
Hi
Has anyone any ideas why i am getting a vectorscript message that reads " preferance set not chosen for this document " when ever i select the simple window or door plugin tool
this has just started since uprading from 9.0 to 9.01
Thanks
Mike
[This message has been edited by MikeS (edited 08-23-2001).]
