Fabrice Spelta Posted October 12, 2009 Share Posted October 12, 2009 To successfully extrude certain 2d shapes i have sometimes converted them into polygones, which is fine visually. But it does turn curves into lots of tiny lines. This is a problem as after using the model to design and visualise for my purposes i then make a 2d flat version of all the shapes and send it off to a CNC router to cut them out. And this machine needs the curves to be curves with the least amount of points to do the best job. SO, the question is how can i make curves out of polygones again? Adobe illustrator offers a function called simplify which simplifies the curves back into just a minimum of points. Does such a function exist in vectorworks? Or which way would you have to go? Quote Link to comment
Ray Libby Posted October 12, 2009 Share Posted October 12, 2009 Welcome to the Community board. I think the better solution would be to extrude without converting to polygons. Could you post a file that exhibits the behavior? I would make it easier to help if you would create a signature with your version of Vectorworks including updates and computer specs including OS. Quote Link to comment
Rossford Posted October 13, 2009 Share Posted October 13, 2009 There is no simplify polygons command in 2D, but there is one in 3D if you have the Designer series packages. If that is the way you choose to go, then convert to 3D poly, simplify, using the VW recommendations or more, and then modify-convert the 3D poly back into a 2D poly. It will have the same number of vertices. Quote Link to comment
Ray Libby Posted October 13, 2009 Share Posted October 13, 2009 Good to know, thanks Jeff! Quote Link to comment
Rossford Posted October 13, 2009 Share Posted October 13, 2009 Ray, Where do I submit the suggestion of adding a simplify 2D Poly command to VW and/or NNA? Quote Link to comment
mike m oz Posted October 13, 2009 Share Posted October 13, 2009 Ross there is a third party simplify 2D polygon command available from Vectorbits: Purge Polygons. http://www.vectorbits.com/VectorBits/donationware/donationware.html Quote Link to comment
Ray Libby Posted October 13, 2009 Share Posted October 13, 2009 Jeff, the Wish List forum is watched by NNA. Quote Link to comment
