thomas reinke Posted August 17, 2001 Share Posted August 17, 2001 Printing from VectorWorks 8.0.0 on Mac OS the print from a HP 5000 N or a HP 2500 CP shows jagged circles. Parallel lines are not parallel and rectangles are without 90 degree angles. Printing resolution is set on best. HP technical support is unable to advice. I am happy for any suggestions. Many thanks. Quote Link to comment
acepernich Posted August 19, 2001 Share Posted August 19, 2001 First, make sure you are printing hi-res in page setup. Pull down File>Page Setup. In pull down @ upper left select the Vectorworks item, click high ersolution printing and select a resolution. A good thing the check first. [This message has been edited by Antone Cepernich (edited 08-19-2001).] Quote Link to comment
