Siva Posted August 17, 2001 Share Posted August 17, 2001 On Metric drawings, even after rounding the decimal to nearest 0 (in Units dialogue box), the dimensions display one decimal point. Of course you can round those dimensions to the neraest 0 again on Object Info Pallette. Thats time consuming to repeat for each dimension again. Is there any solution for this? Quote Link to comment
Guest Posted August 17, 2001 Share Posted August 17, 2001 There are three parts to the units dialog - the first one you see only affects display precision, not dimensions. Use the popup to set primary dimensions. Also make sure you have VW9.0.1. Quote Link to comment
