twonetis Posted September 27, 2009 Share Posted September 27, 2009 Hi, I'm working with 2009 eval version until they get my serial number for my 2010 purchase sorted out, on Monday, I hope. Meanwhile, as a rank beginner, here are a couple of hopefully not too "rank" questions. How do I turn off the Tool Set icons which I don't wish to see or plan to work with - such as machine components or welding symbols? Can I just choose an Architectural interface? I seem to remember this from somewhere, but cannot find it now. Will I be able to find parametric joists, such as steel bar joists and similar components somewhere? Is this a plugin or a library item? Many thanks, two Quote Link to comment
mike m oz Posted September 27, 2009 Share Posted September 27, 2009 It sounds like you are on the Designer workspace. Switch to the Architect workspace (Tools menu - Workspace sub menu is at the bottom). The Framing Member is in the Detailing toolset. In Vw 2010 the steel sections have both a 2D and a 3D opion. Quote Link to comment
twonetis Posted September 28, 2009 Author Share Posted September 28, 2009 Perfect, Thanks very much indeed! Quote Link to comment
