azizg Posted June 14, 2004 Share Posted June 14, 2004 Does any one know where I can find some advice on the best type of 3D objects to use based on file size? I'm making an interior and with all the furniture and props it's becoming a huge file that takes an age to render. Does any one have some advice? Thanks Quote Link to comment
Chris Dordoni Posted June 14, 2004 Share Posted June 14, 2004 Hi Azizg, If you have done a lot of solid modeling operations, you can use "convert to generic solid" to reduce the object's file size. You will lose the "history" of operations that were performed on an object, so it is a good idea to save a copy of your object BEFORE you convert to generic solid. Hope this helps, Chris Quote Link to comment
