wdickert Posted August 15, 2001 Share Posted August 15, 2001 I plot to an old HP Draftmaster II pen plotter. Trying to hide unwanted text, as in VW's title blocks, by covering them with a polygon with line width set to zero does not work. It looks fine on screen but everything behind is plotted. Does anyone know of a workaround, or is there some other way of getting rid of the unused text lines in the title block? Thanks Quote Link to comment
Leslie Posted August 19, 2001 Share Posted August 19, 2001 Assuming you have a reason to keep the "unwanted" text and lines in your file (versus just deleting them for good) - Try setting the class of those items to "non-plot" and then make sure the "Non-Plot" class is set to invisible at the time you send file to the plotter. Shameless plug...<g> Lots of good tips like this can be found in "The Worksbook Architect Companion" to be published soon by "Improbability Press". Go http://www.improbability.com for more info. ------------------ Leslie Sigal Javorek (president) ELLIS JAY Inc. Quote Link to comment
wdickert Posted August 20, 2001 Author Share Posted August 20, 2001 I am talking about the unused lines of text in the standard VW border title blocks, such as project title, design firm address, consultant, etc. These are plugins and can only be edited from the object info pallet. If you delete the unused and unneeded lines of text from the object info pallet a small square will plot in their place. You can ungroup the border but then you lose the ability to edit with the object info pallet. The way it is now you either have to have a long enough project title, enough address lines, consultants, etc, to fill in all the lines, or have little ugly squares, or ungroup and lose the plugin. [This message has been edited by wdickert (edited 08-20-2001).] Quote Link to comment
