Red Jester Posted September 6, 2009 Share Posted September 6, 2009 How do I create a polygon from four separate lines/curves. I have 2 curves and 2 straight lines and I want to create a solid polygon. I have read the vectorworks help service but can't make any sense of it. Quote Link to comment
Pat Stanford Posted September 6, 2009 Share Posted September 6, 2009 Two ways: 1. Make sure the end points of the connecting lines/curves are identical and then use the Compose command from the Modify menu. 2. If the ends overlap, you should be able to use the "paint bucket" mode of the polygon tool to "pour" a new polyline bounded by the lines/curves. Quote Link to comment
mike m oz Posted September 6, 2009 Share Posted September 6, 2009 As long as the ends of the lines and curves actually connect you can use Compose on the Modify menu to turn the four line elements into a single polyline object. Quote Link to comment
Red Jester Posted September 6, 2009 Author Share Posted September 6, 2009 Thanks thats so simple and so much easier to understand than the application help. RJ Quote Link to comment
Kevin McAllister Posted September 6, 2009 Share Posted September 6, 2009 (edited) One of the great things to know about the Polygon Tool "paint bucket" is that you can use it to add bounded areas to an already selected polygon..... hold down the shift key while "painting" into the adjacent bounded area. KM Edited September 6, 2009 by Kevin McAllister Quote Link to comment
IanH Posted September 6, 2009 Share Posted September 6, 2009 Tip: Always save your work before using the paint bucket Quote Link to comment
islandmon Posted September 6, 2009 Share Posted September 6, 2009 Yes ... good advise from all .. and .. especially prior to using joins, trims & paint buckets.. always " save your work " ... these procedures can be more computationally complex than they first appear . Quote Link to comment
