tamarindi Posted September 3, 2009 Share Posted September 3, 2009 On VW2008, whenever I wanted to open a referenced file while working, I double-clicked the VP-> a dialog box opened and after accepting the original referenced file will open. On VW2009 it's not working.....is there another way? or is this a bug? i tried it on different computers..... Quote Link to comment
genie Posted September 3, 2009 Share Posted September 3, 2009 It works the same way in VW 2009. What happens when you dbl click at the viewport & select the "open referenced file" option? Does it give you any message? Quote Link to comment
tamarindi Posted September 3, 2009 Author Share Posted September 3, 2009 no message. Same dialog box as expected.And no response from original file. Just doesn't open. Quote Link to comment
starling75 Posted September 4, 2009 Share Posted September 4, 2009 Hmmm .. same problem. Doubleclicking on a referenced viewport, dialog opens and after confirming nothing happens. Quote Link to comment
tamarindi Posted September 4, 2009 Author Share Posted September 4, 2009 I checked it on PC and MC..... same problem.... Quote Link to comment
Guest ZachP Posted November 11, 2009 Share Posted November 11, 2009 Hi Tami, I've attempted to reproduce this issue, however it seems to be working for me. Are you getting the 'Edit Viewport' dialog and then an Alert asking if you would like to open the referenced file? If not, try resetting your 'Always do the selected action' settings (Preferences->Session->Reset Saved Settings). Does this issue occur all the time, with all files? Could you post a simple test file(s) that displays the problem? Thanks, Zach NNA Quote Link to comment
