Uli Posted August 20, 2009 Share Posted August 20, 2009 Hi, does anybody have a good idea how to make a simple and quick Scaling of hatches inside a Polygon. For example doubleclick the hatch and enter 200%. Up to now I try to use the hardscape tool of landmark but I was only able to rotate the hatch but not to skale it. The way to ungroup and trim is a little bit time-consuming. Maybe I missed something. Regards Uli XP Pro SP3 VW 2008 Landmark Quote Link to comment
eas Posted August 20, 2009 Share Posted August 20, 2009 The only way I know of in VW is to edit the definition of the hatch. This changes all instances of the hatch. So if you want the same hatch at different scales in a drawing you need to make copies and change the scales. We occasionally end up with three or more versions of a hatch in a multiple scale drawing. Quote Link to comment
Dexie Posted August 20, 2009 Share Posted August 20, 2009 You could always rescale the hatches in each viewports using the Advanced properties > Hatch line scale. Quote Link to comment
Uli Posted August 22, 2009 Author Share Posted August 22, 2009 Thank you for your hints. I tried both ways and up to now, I have to experiment a little if it is possible to scale hatches in different objects seperatly in one viewport. Maybe I have to change my workflow a little bit and make a lot of hatches. Anyway I think it would be nice to have just a doubleclick on any hatch and change it seperatly. Quote Link to comment
eas Posted August 25, 2009 Share Posted August 25, 2009 Ex ACad user are you? It can be a hard adjustment. Quote Link to comment
Uli Posted August 25, 2009 Author Share Posted August 25, 2009 Hi eas, thank you for your understanding. The biggest problem for me was that I was used to work with the UCS/WCS all the time and that is really a very quick and good thing for construction. But in VW seems to be more fun inherent. Regards Uli Quote Link to comment
Jim Smith Posted August 25, 2009 Share Posted August 25, 2009 Uli, One may also Hatch from the Modify menu, this creates a series of lines so the object can then be scaled. This can be a quick on-the-fly technique for one off hatches. Here's how: -Draw the Poly required to be hatched, & Scale the object -say by a factor of 0.5, -Select Hatch from the Modify Menu & Hatch this smaller Poly (you will have two things, a scaled down Poly & a Group of Lines in the shape & hatch style you have selected.) - Group these two objects, then Scale them by a factor of 2. This will result in a Group containing the original sized Poly AND a Group of lines in the shape of the Poly that is a Hatch at 200% - not a true hatch, but graphically it looks the same. Quote Link to comment
