Robb Jibson
Rendering Sharkstooth Scrim with transparency.
Greetings,
Trying to render a scene utilizing a scrim material that will show the contents that are behind it. Have been messing around with many materials and none will allow the subjects behind the surface to show through.
Thought I would post here before I attempted to duplicate array 10,000 extruded circles that are .001" thick. Haha.
Robb
Are you using a rendering mode that actually shows transparency?
Have you set the Transparency settings for the material's texture within the Edit Texture dialog?
What distance will this be viewed from?
If it is to be a render of lets say a stage you will not see the actual holes, so the corrct amount of transparency will do.
I use a plain trancparency with logo's to resemble skrims for PA Towers. Looks grear.
If it will be a close up shot and in detail you will need to create a texture....
