sittingduckz Posted August 10, 2009 Share Posted August 10, 2009 I made some changes to PIO's that are used in VW12.5. Since I pasted them back into the plug-ins folder they no long show up in workspace editor or VS Editor. They are definatly in the correct folder. The only thing I can think of is I modified them in VW2009... I'm sure i've done before with no problems? Could this be my issue? Quote Link to comment
Pat Stanford Posted August 10, 2009 Share Posted August 10, 2009 Yes, that is definitely the problem. You have to edit them in the version they are for. Quote Link to comment
sittingduckz Posted August 10, 2009 Author Share Posted August 10, 2009 Bugger! Quote Link to comment
JBenghiat Posted August 12, 2009 Share Posted August 12, 2009 Just to clarify, plug-ins are always forwards compatible (assuming the next version doesn't break the code), but not backward compatible. Always develop plug-ins in the earliest supported VW version. Do you have the old versions? If most of the mods were to the code, you can cut and paste from one version to another (even easier if you're using include files). If you made lots of parameter changes, you'll have to recreate it all. -Josh Quote Link to comment
