michaelk Posted August 9, 2009 Share Posted August 9, 2009 Is this a bug or operator error? In Settings>General>Custom Sash Options... I change the hinge to open the left sash from the right side ... Bad things happen. Thanks! michaelk Quote Link to comment
Guest Wes Gardner Posted August 10, 2009 Share Posted August 10, 2009 Hi, I downloaded your file and could view your window but when I went to create one, I couldn't get mine to fail... What build are you on? Wes Quote Link to comment
michaelk Posted August 10, 2009 Author Share Posted August 10, 2009 It failed on both one computer with SP1 and two computers with SP4. michaelk Quote Link to comment
michaelk Posted August 11, 2009 Author Share Posted August 11, 2009 You opened my file and it didn't have the left sash problem in the pictures? michaelk Quote Link to comment
mike m oz Posted August 11, 2009 Share Posted August 11, 2009 Michaelk if you toggle the OIP Show3DOpen option on and off changing the OpenAngle eventually the missing sash turns up. Is there a reason why you are working in a Layer Scale of 1:1? Quote Link to comment
michaelk Posted August 11, 2009 Author Share Posted August 11, 2009 Mike Good eye. I can get it to show up, but I can't get it to predictably stay. It keeps going away... No reason. This wasn't an actual drawing. I was having the issue on a drawing that was much too big to post, so I opened a blank document and recreated the problem in a simpler setting. michaelk Quote Link to comment
mike m oz Posted August 12, 2009 Share Posted August 12, 2009 Michael bug report it if you haven't done so already. It definitely needs looking at. Quote Link to comment
michaelk Posted August 12, 2009 Author Share Posted August 12, 2009 Mike I reported it. Irregularities seem to happen on any window w/ Custom Sashes of 3 columns when you try to get the outside sashes to hinge on the outside. Thanks for your help michaelk Quote Link to comment
michaelk Posted August 12, 2009 Author Share Posted August 12, 2009 Here's another example. It draws correctly in 3D w/ Show 3D Open selected. But it seems to close incorrectly when it is not selected. michaelk Quote Link to comment
