botto
Wall
Good Afternoon,
How I can make a wall as in the figure?
Thank?s very much,
Pedro Botto
There is a command that does this - the Fit Wall to Roof command. The bad news is that it doesn't exist in Landmark. Therefore you will have to reshape the top of the wall manually by adding vertices to approximate the curve using the 3D Reshape tool. Create a temporary guide by drawing the 2D curve in an elevation view and then extrude this and place it so it is over the top of the wall.
You can do this easily using the Wall tool and then editing with the Fillet Edge tool from the 3D palette. It will no longer be a "wall" but a generic solid.
