Pat Stanford Posted July 24, 2009 Share Posted July 24, 2009 Here is a script that is should clear all Issue data from avery drawing border in a document. Procedure Clear_All_Issue_Data; {This screipt will clear all of the issue data from every drawing border } {(and any other object that has the Issue Data record attached) in a drawing.} {This version has a slight limitation in that the Issue Data table on the} {Border will show :iNo, :iDate, :iNote, etc. for the first issue line until} {you edit the issue data for that border.} {It will also cause some screen flashing as it sets through each layer with } {a border and redraws everything to get the text sizes correct.} {Use at your own risk. No warranty expressed or implied. Do not use while } {operating heavy machinery. May cause drowsieness.} {? 2009, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed unde the GNU Lesser General Public License} Var H1, H2, H3 :Handle; N1, N2, N3 :Integer; Procedure DoIt(H4:Handle); Var H5 :Handle; N4, N5 :Integer; S4 , S5 :String; B4 :Boolean; Begin N4 := 1; B4:=False; While Not B4 do Begin H5:=GetRecord(H4,N4); If H5 <> Nil then Begin S4:=GetName(H5); If S4 = 'Issue Data' then B4:=True else N4:=N4+1; end else Begin B4:=True; end; End; If H5 <> Nil then Begin Layer(GetLName(GetLayer(H4))); N5:=1; While N5 <=50 do Begin S5:=Num2Str(0,N5); SetRField(H4,S4,Concat('Note-',S5),''); SetRField(H4,S4,Concat('Number-',S5),''); SetRField(H4,S4,Concat('Date-',S5),''); SetRField(H4,S4,Concat('Approved-',S5),''); N5:=N5+1; End; ResetObject(H4); RedrawAll; end; End; Begin H1:=ActLayer; N1:=GetLayerOptions; SetLayerOptions(1); RedrawAll; ForEachObject(DoIt,((R IN ['Issue Data']))); Layer(GetLName(H1)); SetLayerOptions(N1); End; Run(Clear_All_Issue_Data); Quote Link to comment
