Undoing a delete turns a "Lighting Device" into a "Light"
Hello,
So the subject pretty much sums this one up. When I delete a fixture, then undo that delete, the fixture re-inserts itself as a "light" (light source with beam, intensity options, etc) instead of a "lighting device" with color, purpose, channel info. The instrument data appears to be lost.
Is this normal? Is there anyway to change this behavior? It's very annoying...
Curious
If you insert a lighting instrument with the Inst Insertion Tool, then undo it "uninserts". But if you Redo, nothing happens.
If you insert a symbol with the normal 2D symbol insertion tool, then undo it "uninserts". But if you Redo, it reinserts.
There seems to be a difference between the 2D Insertion Tool and the Inst Insertion Tool.
michaelk
