David Poiron Posted July 15, 2009 Share Posted July 15, 2009 Using VW2008, I have a DTM with a few site modifier pads. Trouble is they are drawn in red and I cannot figure our how to change this. They even show up as red lines in renderings. I've tried changing attributes, class, and rendering to no avail. There must be a simple way to change this? Quote Link to comment
Guest Frank Brault Posted July 15, 2009 Share Posted July 15, 2009 Hi David, I know of no way to change the color of a Pad. But it's visibility is controlled by the Site-DTM-Modifier class, so you can at least shut it off for rendering. Be sure to turn it back on for Site Model calculations! hth, Quote Link to comment
Thom Posted July 16, 2009 Share Posted July 16, 2009 Actually Frank, a better response would be - "There is no way to change the color, but we should look at the issue, as this would make our product more user friendly." Quote Link to comment
Moe_90 Posted August 29, 2024 Share Posted August 29, 2024 Hello everyone. any updates on that matter? Quote Link to comment
Tom W. Posted August 29, 2024 Share Posted August 29, 2024 1 hour ago, Moe_90 said: Hello everyone. any updates on that matter? I have never needed/wanted to change the colour of Site Modifiers... I just have the Site-DTM-Modifier class invisible by default plus I have my modifiers on a dedicated layer which is also invisible by default. I create a site modifiers Saved View to easily view them when I want to work on them. Ive never had them inadvertently appear in VPs. What is the issue you're having? There's also a hide modifiers command in the View menu. Quote Link to comment
Moe_90 Posted August 29, 2024 Share Posted August 29, 2024 Hallo Tom, thanks for your reply. i want to show the border of the site modifier in the plan in the layout, and they show in the classic red color, which is very strong graphically for presentation. the alternative is to redraw them as polylines, but i thought maybe there is a way to change their color withour redrawing them. Quote Link to comment
Tom W. Posted August 29, 2024 Share Posted August 29, 2024 Aha OK gotcha. Have you checked that the red isn't assigned by the site modifier class...? Never looked myself + not at computer now. The original post was quite old so possible things are different now 1 Quote Link to comment
Tom W. Posted August 29, 2024 Share Posted August 29, 2024 38 minutes ago, Tom W. said: Have you checked that the red isn't assigned by the site modifier class...? Never looked myself + not at computer now. The original post was quite old so possible things are different now Nope that won't work will it given Grade Limits use the same class + have different attributes. Seems you can control the line thickness by class but nothing else. But what you could do is apply a Data Vis to the objects on your site modifier layer in the viewport + change the line colour that way (have just tested + works). So there is a way to change the line colour without redrawing them! 2 Quote Link to comment
