Cadplan Architecture Posted July 8, 2009 Share Posted July 8, 2009 How do you insert wall returns after inserting window and door plug in? I have looked in VW help and it is quite possible but it doesn't really explain how to do it. AJ Quote Link to comment
Jeffrey W Ouellette Posted July 8, 2009 Share Posted July 8, 2009 In the door and window objects, look for the parameters "Interior Components" and "Exterior Components". When you enter a value greater than the default "0" (zero), component returns are enabled. New handles are also exposed on the object, so you can move the termination of the component return around. Quote Link to comment
Cadplan Architecture Posted July 8, 2009 Author Share Posted July 8, 2009 I just tried that and entered 2 for the exterior and interior wall components but it didn't show up any wall return options. I'm in VW2008. Maybe that makes a difference?? AJ Quote Link to comment
Jeffrey W Ouellette Posted July 9, 2009 Share Posted July 9, 2009 Nope. Works the same at least back to v12. Can you see a couple of new blue handles on the object, when the door/window is selected? Quote Link to comment
Cadplan Architecture Posted July 10, 2009 Author Share Posted July 10, 2009 OK I'm there now, it's a bit fiddly but I'll get better at it. Thanks for your patience! AJ Quote Link to comment
