George Lawrence Storm
Earth Berming
I am new to Landmark and an attempting to figure out how to berm a structure.
I have created a site model and placed a massing model on it, half buried in the site model. I them extend a landscaping wall extending from the bottom of my massing model extending out a few feet then turning up at an angle and extending to a contour line at my desired elevation. I adjust my wall to extend over the required base and height. I then place a pad within the junction of my massing model and my landscaping walls and extending back to my desired elevation. I set my pad elevation to the desired elevation.
I cannot get the pad to build my needed contours. I have tried individual fences, using a fence over the entire area and several variations to no avail.
Any suggestions?
Check to make sure that a) "show proposed" is checked, and b) you click "Update".
FWIW, I generally have better success using one fence rather than multiple fences.
I have found that sometimes the DTM - proposed gets a little weird when the original DTM was created using 3D polys and there are a lot of site modifiers. Try converting 3D polys to 3d Loci then creating the DTM then add modifiers.
Good Luck
Dave C.
Hmmmmm, I always use 3D Polys (open pads)within one fence. I have problems getting good results using 3D loci.
