cameleyes Posted July 6, 2009 Share Posted July 6, 2009 Hey, On a recent drawing I sent I suddenly realised after sending that when exported as a PDF my drawing altered. The text in the call out box changed itself from reading "Move DG Socket at least 435mm off corner boxing" to "Move DG Socket at least 435mm of fcorner boxing". The second 'f' in 'off' moved itself on one space. I then noticed wherever I had written 'off' in diff boxes the same thing happened. Design Layer showed it as ok - it only changed on PDF. Anyone know why? I resorted to saying 'from' instead but would rather use 'off' if I can find out how. I've attached an image to show. Thanks Matt Quote Link to comment
Yoginathaswami Posted July 6, 2009 Share Posted July 6, 2009 Try again with different font. It may solve the problem. Quote Link to comment
Jim Smith Posted July 6, 2009 Share Posted July 6, 2009 I NEVER use this tool as each time there is a new iteration of the programme I waste hours finding out that it is not exactly as advertised. I collect my notes as symbols in a file that I can pick & choose. Simple easy & gives me what I need in a call-out, & I can always convert to a group save as a new symbol & add to my call-out file. Quote Link to comment
monkey Posted July 7, 2009 Share Posted July 7, 2009 I have untold problems with the callout tool, about 6 months ago the drop shadow function for the callout box stopped working and has never worked since, have not got a clue why, and if you click to set your insertion point and then zoom out to get some context of where you want to drag it too, the tool stops working and you have to start again, very annoying. Quote Link to comment
Jeffrey W Ouellette Posted July 7, 2009 Share Posted July 7, 2009 Have any of you bother to file bugs regarding the issues you are seeing? Quote Link to comment
cameleyes Posted July 8, 2009 Author Share Posted July 8, 2009 Hey Jeffrey, Thanks for suggestion. How do you do that? Not done it before. Matt Quote Link to comment
brudgers Posted July 8, 2009 Share Posted July 8, 2009 There's a link to bug submit on the right hand side of the page. Quote Link to comment
cameleyes Posted July 9, 2009 Author Share Posted July 9, 2009 Ok thanks for that. Filed the report. I've just realised it happens with whatever font I use and whether it's in a call out box or just text on a page. Image attached shows what I mean. It should read 435mm Off floor (as it does on design layer) Quote Link to comment
cameleyes Posted July 9, 2009 Author Share Posted July 9, 2009 Hey Everyone, Got this reply from Nemetshek today: "Some fonts, even system fonts are not supported well when the Vectorworks Preference, "Quartz Imaging" is turned on. If you turn off this preference on the Display tab of the Vectorworks Preferences, the text should export as expected." Not being the most technical I don't know how that will affect documents but at least people can now read my text. MAtt Quote Link to comment
