workgroup reference on my sack
Here I am with a baseplan workgroup referenced in about 10 other drawings, and for a reason I ignore, although everything was working fine so far, the baseplan moved to the right on all target drawings, whereas in the baseplan itself, it's still centered on the print area. What happened? and what can I do to resolve this?
It sounds like you moved the origin in the baseplan file. If it was formerly set to the center of the page, you can use the set origin command to set it to the document center again.
