Ozzie Posted June 30, 2009 Share Posted June 30, 2009 Hi all - Can anyone import this Wall Mount Clothesline into VW If so what is the trick I have tried File/Import/ImportSketchUp but no go http://sketchup.google.com/3dwarehouse/details?mid=d8ec7c9062ca90d7a2de98ce960b586 Thanks Quote Link to comment
michaelk Posted June 30, 2009 Share Posted June 30, 2009 Weird. Worked right away on my machine. michaelk Quote Link to comment
Ozzie Posted June 30, 2009 Author Share Posted June 30, 2009 michaelk - thanks for that We have two VWs licences - one on my machine which is 64 bit as below and the other - Phils is 32 bit - both versions of VW are identical I just imported it into VW on Phils computer too Wonder if it is because mine is 64 bit Or could there be another reason Darrell Quote Link to comment
Ozzie Posted June 30, 2009 Author Share Posted June 30, 2009 Is there anyone else using Vista 64 bit that has a problem importing Sketchup files with VW 2009 Quote Link to comment
Ozzie Posted July 6, 2009 Author Share Posted July 6, 2009 Sorry to lift this post up but I am still looking for a response from Vista 64 bit users Also today we tested another problem Normally from within a drawing you can select several Symbols and Export them to a Library file or another file On my system only one at a time goes From the Resource Browser no worries export as many as you like in one hit but not from the drawing itself Any other Vista 64 bit users experiencing this? Quote Link to comment
chadoli1 Posted August 25, 2009 Share Posted August 25, 2009 I am in VISTA 64 and Can't Import any sketchup files : ( - PLEASE HELP. Quote Link to comment
brudgers Posted August 25, 2009 Share Posted August 25, 2009 what version of vectorworks? what version of sketchup? Quote Link to comment
bjw Posted September 18, 2009 Share Posted September 18, 2009 I have the same problem with Sketchup imports, doesn't matter if it's SKP 6 or 7, the machine just pinwheels. If I try to export to DWG and then import to VW I get a totally unusable wireframe version. Of course, I've never had much luck going from SKP to VW on either of my Macs. Quote Link to comment
starling75 Posted September 18, 2009 Share Posted September 18, 2009 Sorry to lift this post up but I am still looking for a response from Vista 64 bit users Also today we tested another problem Normally from within a drawing you can select several Symbols and Export them to a Library file or another file On my system only one at a time goes From the Resource Browser no worries export as many as you like in one hit but not from the drawing itself Any other Vista 64 bit users experiencing this? No problem with importing SU files into VW on Vista 64bit. clothesline Quote Link to comment
