Bill Russell Posted June 23, 2009 Share Posted June 23, 2009 Does anyone have any suggestions on creating corner windows or corner storefront/window-walls? I know other addons to VW can do this, but it should be a standard function. Thanks. Quote Link to comment
mike m oz Posted June 23, 2009 Share Posted June 23, 2009 The Window Wall (straight) tool can have mitred ends. The other option is to create your own hybrid 2D/3D symbols. To get the corners correct though you won't be able to insert these into walls. In both cases you will have to form holes in the wall ends using symbols with a hole portion only and then place the hybrid symbols or Window Walls into those holes. Quote Link to comment
Gerrit Posted June 23, 2009 Share Posted June 23, 2009 (edited) Combining the symbol's 2D, 3D and Wall Opening parts (v2009), you can draw a perfect hybrid solution. Edited June 23, 2009 by Gerrit Quote Link to comment
VincentCuclair Posted June 23, 2009 Share Posted June 23, 2009 Combining the symbol's 2D, 3D and Wall Opening parts (v2009), you can draw a perfect hybrid solution. Perhaps you can explain the process a little more for us that haven't tried this.....thanks Gerrit Quote Link to comment
Gerrit Posted June 23, 2009 Share Posted June 23, 2009 Perhaps you can explain the process a little more for us that haven't tried this.....thanks Gerrit Here's a quick-and-dirty step by step (in a hurry right now), please let me know when not clear enough. Please note : 1. the wall opening is available in v2009 (sorry to the original poster who seems to be on v2008) 2. the final step is crucial (exact position of the corner 2D locus) 3. part of the 2D symbol is a white polygon in the background. If you watch the blown up corner carefully, you'll see it continu in the corner itself to cover up the 2D wall) - I've added an additional image to help you understand. 4. of course, the symbol around the corner should be created in the same way. Best of luck ! Quote Link to comment
Bill Russell Posted June 24, 2009 Author Share Posted June 24, 2009 Thanks to all for your input. There are some very creative ideas. Looks like 2009 is a must. Hopefully, VectorWorks will make this easier in future releases. Quote Link to comment
