Israel Posted June 15, 2009 Share Posted June 15, 2009 I set up some keynotes on a preliminary sheet. Later on I developed newer keynotes on another sheet to use across the entire document. Now I can't delete the original keynote list and I can't copy the new keynote list to other sheets. Any help would be appreciated. Quote Link to comment
J Lucas Posted June 16, 2009 Share Posted June 16, 2009 I am not certain, but I think you have to add or delete keynotes individually on a given sheet. This means that unless you put the same exact keynotes on each sheet, then the same notes may have different numbers from sheet to sheet. I use the keynote tool on all my CD's. For better or worse, I have adapted the way I place keynotes to the way the tool works. I do one set of keynotes per sheet and title it "Sheet Keynotes". I group related drawings together on each sheet so that only related keynotes will be on each sheet. Quote Link to comment
Israel Posted June 17, 2009 Author Share Posted June 17, 2009 OK, I get it. But I still can't delete the original set of keynotes which are no longer useful. When I try to place keynotes on that sheet, the old legend keeps popping up. I've tried to delete it but it's very stubborn. Any other thoughts? Quote Link to comment
