We are trying to figure out the best way to create PDF files. It seems that the BATCH EXPORT PDF is the easiest to use and generally creates the best looking files without any major oddities in the print (like stretched text or things disappearing).
The main issue is that generally, the PDF files it creates are abnormally large. Even if we downsample everything.
Conversely, the BATCH PRINT is a little more cumbersome. It makes single files that you have to manually combine in Acrobat. It also seems to have more odd things that happen to the output.
There are two very good things about using the print setup 1. You can print true Grey scale 2. The file sizes are significantly smaller.
But the Batch Print is very frustrating since it has those glitches of disappearing objects and other items appearing out of nowhere???
Does anyone know of a better solution? Also, is there a way to setup the batch print to make one fiels as opposed to separate sheet files?
RickS - Lab 8
Thanks!
0 answers to this question
