MaxStudio
Predefine Function?
Is there a way to predefine a function and label it so I can call it when needed instead of retyping it over and over again?
You can create a file which has common functions and $include it into other scripts.
However care is needed to make sure that you do not create inter functional dependencies.
thanks Ian,
include would definitely work. Although, i'm looking to do the exact same thing as $include, but contain it all in a single file.
any ideas?
Thanks for your help.
derek
Are you saying you are using the same function over and over in the same file?
yes exactly
i guess it would be a procedure (sub-procedure) rather than a function.
Edited by MaxStudio
I got the following test to work using sub-procedures. I get confused about where to put things when there are so many end's... lol
Procedure ProSub;
VAR
result:LONGINT;
gA, gB: BOOLEAN;
A,B,C,D: REAL;
FUNCTION DED_ProSub(VAR id:LONGINT):BOOLEAN;
BEGIN
{ initialize dialog creation }
id := CreateLayout('Procedure/Sub-Procedure',TRUE,'Create','Cancel');
{ Menu 1 }
CreateStaticText(id,4,'Type:',-1);
CreateCheckBox(id,5,'A.');
CreateCheckBox(id,6,'B.');
{ Layout Dialog }
SetFirstLayoutItem(id,4);
SetRightItem(id, 4, 5, 0, 0);
SetRightItem(id, 5, 6, 0, 0);
DED_ProSub:=VerifyLayout(id);
END;
PROCEDURE DD_ProSub(VAR item:LONGINT; data:LONGINT);
BEGIN; { SET DEFAULTS }
CASE item OF
SetupDialogC: BEGIN
SetItemEnable(5,TRUE);
SetItemEnable(6,TRUE);
END;
1:BEGIN
IF ItemSel(5) THEN gA:= TRUE ELSE gA:= FALSE;
IF ItemSel(6) THEN gB:= TRUE ELSE gB:= FALSE;
END;
END;
END;
{ Begin Define Sub-Procedures ------------------------------- }
Procedure Sub;
BEGIN
Rect(A,B,C*2,D*2);
END;
Procedure Sub2;
BEGIN
Rect(A,B,C*4,D*4);
END;
{ End Define Sub-Procedures -------------------------------- }
BEGIN
IF DED_ProSub(id) THEN BEGIN
result:=RunLayoutDialog(id,DD_ProSub);
END;
IF (result=1) THEN BEGIN
A:=0;
B:=0;
C:=50;
D:=50;
IF gA THEN BEGIN
Sub2;
END;
IF gB THEN BEGIN
Sub;
END;
END;
END;
RUN(ProSub);
To avoid confusion with begin and ends, use indentation. There are different styles with this, but all my commercial programming life, I tab (typically 8 spaces) indented after any begin and reverted back before the end.
eg. but only using 4 spaces. Programming style is largely personal style so I would format this differently than you have done, but there are some things that are good practice/corporate style rather than just personal style.
One thing you could have done is create a single function sub and passed a variable as a scaling factor.
Procedure ProSub;
VAR
   result  : LONGINT;
   gA, gB  : BOOLEAN;
   A,B,C,D : REAL;
BEGIN
   id := CreateLayout('Procedure/SubProcedure',
   { Menu 1 }
   { Layout Dialog }
END;
BEGIN { SET DEFAULTS }
   CASE item OF
       SetupDialogC:
       BEGIN
       END;
       1:
       BEGIN
       END;
   END;
END;
Procedure Sub;
BEGIN
   Rect(A,B,C*2,D*2);
END;
Procedure Sub2;
BEGIN
   Rect(A,B,C*4,D*4);
END;
BEGIN
   BEGIN
   END;
   IF (result=1) THEN
   BEGIN
       A:=0;
       B:=0;
       C:=50;
       D:=50;
       IF gA THEN
       BEGIN
           Sub2;
       END;
       IF gB THEN
       BEGIN
           Sub;
       END;
   END;
END;
RUN(ProSub);
Forgive me if you already know this, but have you looked at the VS Language Guide? It's available through the VW help system. There's a section called User Defined Functions that you may find useful.
-Josh
Hey Josh! Thanks a lot for pointing out that section in the language guide. "subroutines" is exactly what I was trying to accomplish.
Ian, thanks for your help. I'm going to try to keep my scripts more organized using the indentation method you have shared with us.
