Channel Hookup Sorting
A new problem I have never had before. After I generate the paperwork, the Channel Hookup is NOT in numerical order. I cannot figure out just how it decided to order it, but I cannot find any way to quickly resort and the manual is very mum on the subject. Any ideas?
Thanks.
M. Sachs
Tulane University
Which version are you using? Does it appear that the channel numbers are sorted alphabetically?
If you are using the Report>Generate Paperwork... command to generate paperwork, just selecting Channel Hookup forces it to sort by channel. If that's the case, then something strange has happened.
But if you are using your own report, then you need to include and sort by the alt-chan field. But don't try to edit the alt-chan field.
hth
michaelk
