AutoCAD Stretch in VW
That's the key, Bob. I had toyed with 2D Reshape before but couldn't quite get it to mimic what they were used to in ACAD. The help file doesn't really explain it for the layman, only mentions the fact you can use marquee and doesn't explain how it works.
  • 5 years later...
Method:
- select the objects you want to stretch.
- activate the Reshape tool and draw a marquee around the object handle points you want to move.
- move the marquee the required distance. Use the floating data bar to enter precise values.
- deselect on completion of the stretch.
Notes:
- you can also use the Move command to move the object handles.
- symbols and groups can't be stretched using this method.
  • 1 year later...
