cberg Posted July 5, 2001 Share Posted July 5, 2001 Working in Vector Works version 9.0, I have been having troubles with the trim command in relatively large 2-D drawing files (3-5+MB). When I draw 2 intersecting lines and use the trim command, instead of trimming, one line will disappear. I have been forced to use the less useful split tool. In smaller files, or brand new files this problem seems to disappear. Has anybody else come across this problem? And if so, is there a workaround? We have heard that the new patch 9.01 will not fix trim problems, so we await 9.02. Quote Link to comment
Niall Posted July 13, 2001 Share Posted July 13, 2001 If you group and edit the lines you wish to trim, should work. Quote Link to comment
